Instrumentation amplifier question
msr
Joined Jul 8, 2008
64
Can I use an instrumentation amplifier like a common opamp?
In particular, I would like to know if I can use a INA118 like an opamp inverting circuit?
Thanks for your help!
Audioguru
Joined Dec 20, 2007
11,248
If you look at the datasheet of the instrumentation amplifier, you will see that it already has negative feedback and its gain is set completely differently than an opamp.
With an opamp, you must add your own negative feedback that determines the gain.
If you add a gain-setting resistor then an instrumentation amplifier makes an inverting amplifier with a very high input impedance.
