Inside laptop battery enquiry
turboid
Joined Jun 13, 2023
What are these small white plastic things, that are in my laptop battery, between my laptop and the battery cells? Are they required if i change the cells?20230613_130948.jpg
Externet
Joined Nov 29, 2005
2,665
Can be fuses, thermal fuses, thermal circuit breakers, resettable or not, necessary if you want to implement protection from mishappenings or circuit faults.
Tonyr1084
Joined Sep 24, 2015
9,744
If you're NOT talking about the fairly obvious component, those white plastic things are insulators. They're there to prevent short circuits. If you're talking about the component with markings under the red marker - looks like a fuse to me as well.
Externet
Joined Nov 29, 2005
2,665
Can someone explain, if the fuse/breaker/whatever is/are 'F' below, in what events or situations or happenings, how does it protect from the cells catching fire ? Is it for short circuits (+) to (-) ?
(+)------F-----(+)cell1(-)------F-----(+)cell2(-)------F-----(+)cell3(-)------(-)
Poyntat
Joined May 24, 2022
60
It’s a Litttelfuse thermal cutout.
I think the one shown is re- settable in that it will open when it’s temperature exceeds 77 degrees C and will close when the temperature drops.
This particular part is obsolete, check out MPH-TA 15-9-77.
Without these components the pack is a potential fire bomb.
ThePanMan
Joined Mar 13, 2020
950
If the battery pack is overloaded or not charged properly the self-resetting fuse will open and hopefully prevent a thermal runaway condition (where the battery becomes a flame thrower if you've never seen a video of a lithium cell light off). I don't think it disconnects one battery from the rest, the battery pack should be a series of batteries. ANY thermal excursion will open the circuit and disconnect the battery from either the load or the charger.
WBahn
Joined Mar 31, 2012
33,089
Ask yourself this: If you are a manufacturer of laptop batteries, would you spend the money to put things in there that serve no purpose?
