Inrush current for 775 motor and power supply
r2m
Joined Aug 8, 2018
ECFD5291-5F0C-4ECB-B531-F71D25F1A24C.jpeg I have two power adapters and, this may be a dumb question, but one of them is triggered off because of a high inrush current of a 775 dc motor, and the other has just a smooth start and is working ok. The power supply that works ok is 2A and the one that shuts down rated as 4A
So... what’s the deal?.. is one switching power supply the the other is not?
Hymie
Joined Mar 30, 2018
1,347
Both are switch mode power supplies – this is evident from the input voltage range 100-240V~.
It is likely that the motor inrush current is sufficient to cause a momentary overload condition which is causing the 4A output rated unit to shut down.
You could confirm this by adding a small resistance (say 2Ω) in series with the output.
You might find a low resistance NTC device that you could wire permanently is series with the output that would not compromise the motor performance.
MaxHeadRoom
Joined Jul 18, 2013
30,842
Bit ridiculous rating for that motor if it is the RS-775 at 43.9amps stall current!!
Easy to check by applying low voltage to locked rotor and measure the current.
Check different spots for lowest reading.
Max.
r2m
Joined Aug 8, 2018
Thanks for the answers.
I tried, of course, with both, 2ohm resistor and NTC, just to verify, both worked well, resistor is taking too much power and the NTC getting hot because the one I have is not suitable for these currents, but what amazes me is that I also tried with a 38A power supply of an old IBM workstation, and it also going into current load safe mode! So I really don’t understand what is so special in the small PS?
MaxHeadRoom
Joined Jul 18, 2013
30,842
Maybe goes into a type of current limit mode until motor starts to rotate, the faster this happens the lower the current.
Max.
