input clamp current in a datasheet
bug13
Joined Feb 13, 2012
2,002
Hi guys
I need to location the input clamp current in this datasheet:
http://ww1.microchip.com/downloads/en/devicedoc/39682e.pdf
Here is how I usually do it:
  • search keyword "clamp" in the datasheet, or
  • look at section "Electrical Characteristics" in the datasheet, section 24.0 for this device.
But I cannot find any info about the input clamp current for this device, where else can I look in the datasheet for this PIC?
38,504
The data sheet does state "I/O pins have diode protection to VDD and VSS" but I found no mention of their maximum current.
If the input voltage can go below ground or above the Vsupply, I would limit the current to no more than a couple mA.
The maximum sink current is determined by the output transistor size and has no relation to the maximum protection diode current.
bug13
Joined Feb 13, 2012
2,002
Thanks for confirming. I would have thought these basic info such as input clamping current is a must in a datasheet, apparently not.
