Initialization of Variable in C
Parth786
Joined Jun 19, 2017
642
I am confusion on initialization of variable in c. C variables are names used for storing a data value to locations in memory
Declaration of variable in c can be done using following syntax:
data_type variable_name;
Example: int i; where i is variable name. this is example of variable declaration with single name
or
data_type variable1, variable2,…,variablen;
Example: int i, j,k; this is example of variable declaration with multiple name
assign value to variable name
example: int i = 6;
Than initialization of variable look like this
syntax: for(initialization; test; increment)
Example: for(i=0; <5; i++);
Declaration and initialization
int i;
for(i=0;i<5;i++);
compiler set i=0 and then increment by 1
program output 0,1,2,3,4
can we initialization like this? I think no
int i=2;
for(i=0;i<5;i++);
this program show output 0,1,2,3,4. why does it not show 2,3,4 while int i=2;
what happens to declared but uninitialized variable. does it have a value?
shteii01
Joined Feb 19, 2010
4,644
int i=2: means that you have variable i that is integer and you store 2 in this variable. here you did two things, initialize i and store a value in it.
but
then in the for loop you say that you will store zero in variable i. so you replaced 2 with a zero. you did not initialize anything when you wrote for loop.
Parth786
Joined Jun 19, 2017
642
but
I understood so the correct statement is
Code:
int main ()
      unsigned int i;
      for (i=0; i<4; i++);
Brian Griffin
Joined May 17, 2013
64
Before the loop, you set the i to '2'. Then afterwards, the conditions for the 'for' loop has the i being set to '0'. Therefore it only shows 0,1,2,3,4.
Brian Griffin
Joined May 17, 2013
64
Code:
int main ()
      unsigned int i;
The 'i' is still being used in the loop. Therefore, the 'i' has a value in the loop. The compiler will pick this up as a warning if it is uninitialized.
Parth786
Joined Jun 19, 2017
642
I googled for local and global variables. A local variable is a variable that is declared inside a function. A global variable is a variable that is declared outside all functions. A local variable can only be used in the function where it is declared. A global variable can be used in all functions.
example for local variable
Code:
int main ()
      unsigned int i;  // Local variable
example for global variable
Code:
     void delay ()
     unsigned int i; // Global variables
    int main()
     /* program code
when do we need global or local variables in c program?
Papabravo
Joined Feb 24, 2006
22,116
Variable are initialized in the C startup routine that is done before the call to main(). Uninitialized variable are set to zero by most C startup routines I have seen. The initialization does not set a variable to zero and then increment it to get to some non-zero value. That would be a**holish.
djsfantasi
Joined Apr 11, 2010
9,237
But that is not reliable. Your compiler may set it to anything or not at all. Knowing this, you should adopt the practice of always initialize your variables upon declaration.
35,089
Initialized variable does not mean that it is initialized to zero.
Uninitialized variable means that its value could be any value.
There is no need to initialize your variables.
Always assign a value to a variable before you read the variable as data in any function, expression or control variable.
Parth786
Joined Jun 19, 2017
642
I have doubt in my post number 6. there tried to explain local and global variable and not sure that I understand correct logic of local and global variable. do you find any mistake.
when do we need to use global and local variable in program?
35,089
As you have correctly described, local variables are accessible in the function where they are declared.
Global variables are accessible everywhere.
Here is one example of usage of local and global variables:
Code:
// create a global variable
int Sum;
void function1(void)
int i;
for (i = 0; i < 10; i++)
  Sum = 0;
  function2(35);
void function2(int n)
int i;
for (i = 0; i < n; i++)
  function3( );
  Sum += Data[i];
Here, we can reuse the loop counter i in nested functions without conflict because the scope of each i is local to the function.
Sum is an example of a globally declared variable.
We can initialize the value of Sum in one function and then accumulate Sum in another function.
(These are just examples and are not intended to represent any useful code.)
35,089
Your example in post #6 is technically incorrect.
Here is your example modified:
Code:
unsigned int i; //global variable
void delay (unsigned int n)
     unsigned int i; // local variable
     for (i=0; i<n; i++);
void main(void)
     /* program code
    delay(4);
JohnInTX
Joined Jun 26, 2012
4,787
@Parth786 One of your major problems is the text you are using (posted on another thread). It gives minimal, show and tell examples that have some value but won't teach you much about C. Get a copy of The C Programming Language 2ed ed. or later. Most if not all of your C questions will be answered in a concise, clear manner in that book. The fact that you can't figure out when to use a specific 'storage class' and 'scope' means that your current resources are lacking in depth (storage class and scope are not even discussed in your text) and you need something more.
There are also a gazillion tutorial sites online but I prefer to get my C straight from the guys who wrote the language.
I would also download the manual for the compiler you are using and read it from cover to cover.
Good luck.
