Initial state of 4043 latch outputs
Dave65
Joined Nov 1, 2015
4
I'm powering up a 4043 SR latch with S and R both tied low. The output is always high at power up which feels a bit counter intuitive, given that S has not been given a high.
I understand that the S and R lows would cause the output to latch in whatever state the output was, but why is this high (at power up?)
I suppose my question is, is this expected SR latch (4043 in particular) behaviour? If it is then I'll need to implement something to give R a brief high at power up to force the output low.
Many thanks
RamaD
Joined Dec 4, 2009
328
There is nothing mentioned in the data sheet about the output state with both R & S inputs low while powering on. The behaviour could be different for parts from different manufacturers. If any known output state is required on power on, then that must be forced like you had suggested.
Alec_t
Joined Sep 17, 2013
15,156
If the latch is consistently in one particular state at power-up, and that state is the opposite of what you want, then just swap the Q and not-Q output connections.
dl324
Joined Mar 30, 2015
18,465
A slight problem is that CD4043 don't have complementary outputs:eek:
dl324
Joined Mar 30, 2015
18,465
If you trace the logic, you'll find that you're seeing the expected state. Below is an annotated schematic of the logic which shows why.
The only "difficulty" in analyzing latch output is you have to make an assumption. If you guess wrong, you have to walk through the logic again.
dl324
Joined Mar 30, 2015
18,465
For completeness, here is the annotated schematic for the CD4044 NAND version:
That gate would have a LOW output with both inputs tied LOW.
Roderick Young
Joined Feb 22, 2015
408
If it's not practical to pulse R high digitally at power up, you could always put a 0.01 uF capacitor between Vdd and the R input, and drive the input through a 1k resistor. That sort of thing is frowned upon in commercial designs, but if this is a hobby project, it should work fine.
Dave65
Joined Nov 1, 2015
4
Just wanted to say many thanks for everyone's replies to what was my first question in this forum :)
I've found it a very useful site/forum and I'm sure I'll be asking further questions in future.
Cheers
Dave
