Infrared CCTV Camera Light Schematic and Board Layout
ericgibbs
Joined Jan 29, 2010
21,601
hi N,
I use the same type IR light unit, I under run the 12Vdc at ~10Vdc, mine have run almost 3 years, no problems.
IIRC the current draw is approx 160mA to 200mA, so a 10R would also drop about 2V
On one Camera+ light unit I used a supposed 12Vdc wart PSU, which actually output 15Vdc, the light lasted less than a week.!:rolleyes:
I now use that Camera [with no IR] inside the house, looking out thru a window.
The outside IR lights provide enough illumination for a very good night image and I don't get the windows internal reflection back into the camera.
E
Thanks for the circuit diagram.
