Hi!
I need some information on this circuit if possible. I found it, while searching for a Bluetooth module, its ultra low power, but the datasheet did not contain a circuit and did not help me enough. Is the circuit correct, do you suggest any improvements? The Bluetooth module has an internal crystal of 32MHz, while PIC16F877A, needs an external crystal. Is there any way to use the Bluetooth crystal, has someone had experience with this module?
Thanks in advance.
Thanks in advance.
