Infinite Capacitance _ Capacitor Diagnosis
ben sorenson
Joined Feb 28, 2022
181
Hello, I was wondering if a capacitor with infinite capacitance existed how could one diagnose it to verify that it actually infact did have "infinite" capacitance?
KL7AJ72
Joined Apr 15, 2021
22
This would present an untenable paradox. We run across a similar situation when looking at the ionosphere when there's no propagation. Two exact opposite conditions can have the exact same result. No ionization= no ionosphere. Excessive ionization= total absorption. Same results...no radio propagation.
BobTPH
Joined Jun 5, 2013
11,659
I guess it would be indistinguishable from a zero Ohm resistor. You could keep putting current into (or through) either and it would never develop a voltage across it.
Hymie
Joined Mar 30, 2018
1,347
The ac impedance of the capacitor would be zero; how accurately you could measure zero impedance would determine how accurately you would determine the capacitance to be infinite.
BobTPH
Joined Jun 5, 2013
11,659
Proposed final exam at Hogwart’s School of Electronics.
You have 3 black boxes with two terminals each. They contain:
1. An infinite Farad capacitor.
2. A zero Ohm resistor.
3. A zero Henry inductor.
Determine which is which by any means you think might work.
billnow
Joined Aug 4, 2010
23
I would label all three as item "A" and then state that each item "A" is a perfect substitute for any other item "A".
ben sorenson
Joined Feb 28, 2022
181
What would be the most accurate way to measure for infinite capacitance?
ElectricSpidey
Joined Dec 2, 2017
3,359
Well, maybe all capacitors have infinite capacitance...think about it.
First a capacitor must fill with half of the charge, then fill half of the remaining capacity, then fill half of that remaining capacity...
KL7AJ72
Joined Apr 15, 2021
22
There's a genuine mixed bag here. I'm never averse to telling my students "Infinity is a number too." It just needs to be used appropriately.
Ya’akov
Joined Jan 27, 2019
10,307
Assuming they contain what they are labelled, no testing is required.
For boxes 1, 2, and 3:
  1. 1 is the capacitor, resistor, or inductor
  2. 2 is the capacitor, resistor, or inductor
  3. 3 is the capacitor, resistor, or inductor
The application of each is at the discretion of the user.
Hymie
Joined Mar 30, 2018
1,347
Hymie said:-
The impedance (Z) of a capacitor (C) at a given frequency (f) is given by:-
Z = 1/(2 * π * f * C)
Therefore as C tends towards infinity, Z will tend towards zero; therefore the more accurately the ultra low value of Z can be determined, the greater the accuracy in determination of a very large capacitor value.
Ian0
Joined Aug 7, 2020
13,286
An infinite capacitor must have infinite plate area*, but it doesn't need infinite plate thickness, so the plates can have non-negligible resistance, which would also be infinite. Doesn't that turns it into some sort of lossy transmission line?
*I suppose it could have dielectric of infinitesimal thickness, but then it would have almost zero voltage rating.
