I have tried to simulate an inductive spike on ltspice. Had no luck. I have used an n type mosfet rated at over 200v. Very small current with this one. Easier than trying to use the voltage controlled switch.
The simulation shows no large spike which should be there on switching off or on. I have attached an asc file showing the connections.
Can anybody explain why the simulation does not show any large spikes?
I can see that the asc file does not show the result of the simulation. But from the schematic anybody with ltspice can run the simulation and will see that there is no large inductive spikes?
