Induction cooktop repair help which is in on/off loop when heating starts.
rahul411
Joined Feb 19, 2018
260
I have a induction cooktop which failed about 2 years ago, it was kept like this the whole time and now I'm starting to repair it.
At first glance it was fuse which was blown which was caused due to IGBT failure, so i replaced that and also the big capacitors. Now it seems to work but the thing is, it switches on off by itself. But it also heats the metal kept on it.
jpanhalt
Joined Jan 18, 2008
11,087
Please clarify, "it switches on off by itself. " Do you mean you cannot turn the burner off or does it cycle on/off when you turn it on? The latter might be normal.
Apparently your video shows the latter. Are you sure that is not normal with the load you have on it?
jpanhalt
Joined Jan 18, 2008
11,087
From what I understand of your description, the circuit probably has an overload sensor, and that trips as the load increases. If a resistor is used for that, check that it is the correct value. They are usually quite low values, like ≤0.1Ω. It could also be a thermal switch.
rahul411
Joined Feb 19, 2018
260
About the thermal switch- there is a ntc thermistor underneath IGBT with a odd value of 66k at room temperature (around 30C). I touched it with solder and resistance fall down meaning it works but idk if that 66k ntc is standard value. Because what i know it is either 100k or 50k @25C. Even with 30C the resistance mustn't fall this much.. what you think?
jpanhalt
Joined Jan 18, 2008
11,087
This is one chart (center column = °C, right column = Ω):
66k would be about 34°. Were you holding it in your hand? The problem, if there is one, is probably elsewhere. Does it work as intended when re-assembled to the stove top? Your original post says it heats. Does it not heat properly?
bertus
Joined Apr 5, 2008
22,994
What does the manual say about heating rate?
I know that some induction cooktops check the heating rate and when the heating rate is to low, the heating will stop.
Bertus
rahul411
Joined Feb 19, 2018
260
Yea it heats as it was before but in on off cycle, as you can see in video the bulb is blinking. That is how it is working now and with big wide pan kept on coil the device fully turns off.
rahul411
Joined Feb 19, 2018
260
Bertus
Sorry but I do not have heating rate value, but this is common induction cooktop with 2000W power rating.
