Require an indicator light to illuminate whenever a pivoting blade contacts a machine frame.
Blade is electrically isolated from the frame (a circuit wire can be connected to the blade).
Machine has a 24VDC power supply; however, a separate 12 or 24VDC supply will be used.
Circuit will operate independently of the machine’s PLC.
Circuit components:
1. Switch (metal contacts comprising a knife-blade closing on a machine frame).
2. Power supply.
3. Indicator LED.
4. Various discrete components.
In summary we need to use frame ground (not -VDC) to complete the circuit.
Circuit components:
2. Power supply.
3. Indicator LED.
