Incremental Encoder output
MaxHeadRoom
Joined Jul 18, 2013
30,654
The output bit pattern is supposed to be a Gray code, therefore under no circumstances should two outputs be changing simultaneously...
Not according to the sheet which shows typical quadrature?
The change occurs midway between indent, so it appears to be geared to very slow rotation rates.
OP: What is your application?
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,654
Then I would suggest to take a sample output while turning slowly manually and monitor output with a meter.
If necessary chart output via a simple 360° protractor on the shaft.
The transition should occur midway between indents.
Max.
