increasing frequency of ramp generator
Chandler Timm Doloriel
Joined Apr 5, 2018
54
Hello everyone!
In my simulation of ramp generator, I only get small frequency below 100kHz. How should I increase the frequency to 250kHz? I tried changing Io, Ct and Rt but it only results to bad output.
Here are my values that I get a 33kHz triangular output:
Io = 33uA
Ct = 1nF (0.55V)
Rt = 5k
Vdd = 1.2V
In any of these parameters, Io is the most valuable I think? What value should I increase it to result to better output?
Thank you for your time reading this
danadak
Joined Mar 10, 2018
4,057
Depends on -
1) MN2 Rdson limits speed of discharge of cap.
2) MN2 gate driver speed handling MN2's input C.
3) Speed of hysteresis driver in MN2s gate drive path.
4) Speed MN2 can be turned off.
5) Parasitics associated with ramp cap.
Regards, Dana.
ebp
Joined Feb 8, 2018
2,332
Look for clues, such as by reducing the capacitance by a factor of 10 and the output current by a factor of two. What would you expect? What does the simulation show?
Showing a sim for a whole bunch of apparently identical cycles just obscures the details. If nothing is shifting with successive cycles, showing 2 or 3 is far better.
RichardO
Joined May 4, 2013
2,270
If you use LTspice for your simulation others will be able to see better exactly what you are doing. Please post the .asc file if you use LTspice.
