increase voltage from 2.2 to over 3
trickyrick
Joined Sep 18, 2013
80
#12
Joined Nov 30, 2010
18,224
"The sensor either gives off a 3.3volt high value when motion is detected and then resumes or continues to give off a 0 voltage when no motion is detected."
"High level output: 3.3 V / low 0V"
Why is your board not obeying its specifications?
trickyrick
Joined Sep 18, 2013
80
If I meter the output of the motion sensor with no load its 3.3v but when I connect it to the module it drops to 2.2 volts. I was thinking about using a Mosfet or scr but I think they all switch the negative side of the line.
#12
Joined Nov 30, 2010
18,224
trickyrick
Joined Sep 18, 2013
80
Thanks for the info I didn't have one of the devices above so I used an scr and a mini relay to do the job. Wasn't as elegant as what you suggested but I had the parts.
rick
#12
Joined Nov 30, 2010
18,224
Good enough.;)
You took the basic principle of what was wrong and found a way. That's what design work is about.:cool:
joeyd999
Joined Jun 6, 2011
6,279
rick
IOW, you McGyvered a solution. Excellent.
I would've used bubblegum and a matchstick, but, each to his own...
