I currently place my temperature alert units outside my trailers because the signal does not get to the receiver when placed inside the unit. I am looking to boost the signal in order to place inside the unit for better readings.
The Temperature Alert unit is Model TM-ZP200 Rev B
It has a coax output that runs to the antenna.
If I add an external Op-Amp between the unit and the antenna, will this solve the range issue?
