Increase IR range
LesJones
Joined Jan 8, 2017
4,539
Here is the pattern that I found to work with a TSOP4838 when using it for beam break detection.
Format.
start
30 cycles of 38 Khz (789 uS)
Gap of equivalent length to 30 cycles of 38 Khz (789 uS)
Loop 20 times to start
delay about 25 mS
Go back to start
This is the code I used to generate this pattern using an ATtiny13A.
Code:
 * _38Khx_beam_V03.asm
 *  Created: 02/03/2022 16:02:42
 *   Author: Les
 ;    using ATTINY13
;Use internal clock at 9.6 Mhz  and divide by 1 by setting CKDIV8 fuse bit
;(So Instruction time = 104.17 nS)
;38 Khz is 13.15 uS on and 13.15 uS off.   13.15/0.10417 = 126 instruction cycles
.list
;.include    <tn13def.inc>    ; ATtiny 13
.list
.listmac
;* Global Register Variables
; Note register number is in decimal
.def    temp1        = r16    ; Temporary register 1
.def    temp2        = r17    ; Temporary register 2
.def    count_L        = r18    ; Counter low byte
.def    count_H        = r19    ; Counter high byte
.def    count2        = r20
.def    cycles_L        = r21    ; Counter
.def    cycles_H        = r22
.def    Burst_count        = r23
;************************************* MACROS *****************************
;******************************** INTERRUPT VECTORS ***********************
.CSEG
.ORG    $00
    rjmp    reset
    reti
    reti
    reti
    reti
    reti    ;    rjmp    timer1_OVF
    reti
    reti
    reti
    reti
;********************************** TABLES ********************************
;******************************* RESET *************************************
; Initialise the stack-pointer
reset:
    ldi    R16,low(RAMEND)
    out    SPL,temp1
;    ldi    R16,high(RAMEND)
;    out    SPH,temp1
; initialize PORTB
;    Bit 0    Input
;    Bit 1    Input
;    Bit 2    Input
;    Bit 3    Output  (Pin 2)
;    Bit 4    Output    (Pin 3)
;    Bit 5    Input
    ldi    R16,0x18    ; Bits 3 and 4 as outputs.
    out    DDRB,temp1    ;
    ldi    R16,0x08
    out    PORTB,temp1    ; PORTB Bit 3 high, bit 4 low
;Set prescaler to value of 1
    ldi R16,0x80        ;Set bit 7
    out    CLKPR,temp1    ;
    ldi R16,0x00
    out    CLKPR,temp1    ;
;Initialize Timer 0
;                    Main program code
Main:
Wave_loop:
    ldi    count2, 0x14    ; (20 decimal)
cycle30_Burst:            ;Send burst for high state
    ldi    Burst_count,0x1E ; 30 decimal    ;Burst lengthe will be 60 * 13.15 uS = 789 uS
Burst_loop:                                            ;Loop is 23 instruction cycles (22 * 0.10417 uS = 2.29 uS) + delays
    ldi    R16,0x08                                    ;1 instruction cycle
    out    PORTB,R16    ; PORTB Bit 3 high, bit 4 low   ;1 instruction cycle
    rcall     Delay_13_15_uS                            ;3 instruction cycle + delay + 4 for return
    ldi    R16,0x10                                    ;1 instruction cycle
    out    PORTB,R16    ; PORTB Bit 3 low, bit 4 high    ;1 instruction cycle
;    rjmp    Burst_loop                                ;This instruction is only inserted for testing generated frequency.
    dec    Burst_count                                    ;1 instruction cycle
    tst    Burst_count                                    ;1 instruction cycle
    brne    Burst_loop                                ;2 instruction cycles for branch, 1 for not branch
NB_delay:            ; Delay for 789 uS
;    ldi    Burst_count,0x3C ; 60 decimal
   ldi    Burst_count,0x78 ;120 decimal
NB_01:
    dec    Burst_count
    tst    Burst_count
    brne    NB_01
    dec count2
    tst count2
    brne    cycle30_Burst
    rcall Delay_25mS
    rjmp    Wave_loop                                ;2 instruction cycle
;Subroutines.
;    * Delay 13.15 uS. This is 126 instruction cycles        *
;    * Once round the loop is 4 instructions        *
;    * 126/4 = 31.5 So count 31 loops        *
;    * So subtract 3 from this gives 28        *
;Total delay will be (count  * 4 * instruction cycle time ) +   1 instruction time. (Instruction time 0.10417 uS  * 4 - 0.10417 uS                    *
; As delay is called twice in waveform loop which includes 22 instruction cycles need to subtract 11 instructions from delay loop to compensate.    *
; So subtract 3 from loop count        *
Delay_13_15_uS:
    ldi     count_L,0x1B    ;Decimal 28  (Once round the loop is 4 instructions)
D_13_15_Loop:
    dec    count_L        ; Count_L is R18
    tst     count_L
    brne     D_13_15_Loop    ;If not zero
    ret
; *    Delay_25mS        *
; * 25 mS is 25000 uS instruction time is 0.10417 uS                                                    *
; * 25000/0.10417 = 239992 instruction cycles  (239992 cycles = 0x3A978 )                                *
; * As the loop is 8 instruction cycle long count need to be 239992/8 = 29999 = 0x752F                    *
Delay_25mS:
    ldi     count_L,0x2F    ;Decimal 29999
    ldi     count_H,0x75
    rjmp    D_1mS_Loop1
; *    Delay_1mS        *
; * 1 mS is 1000 uS instruction time is 0.10417 uS                                                        *
; * 1000/0.10417 = 9599.7 instruction cycles  (9600 cycles = 0x2580 )                                    *
; * As the loop is 8 instruction cycle long count need to be 9600/8 = 1200 = 0x04B0                        *
Delay_1mS:
    ldi     count_L,0xB0    ;Decimal 1200
    ldi     count_H,0x04
D_1mS_Loop1:                        ;Loop is 8 instructions long
    nop    ; nop's are so the timing is the same a when it goes through the high byte code
    nop
    nop
D_1mS_Loop2:
    tst     count_L                        ;1 instruction cycle
    breq    Test_H                        ;2 instruction cycles for branch, 1 for not branch
    dec    count_L        ; Count_L is R18     ;1 instruction cycle
    rjmp    D_1mS_Loop1    ;If not zero    ;2 instruction cycles
Test_H:
    tst     count_H                        ;1 instruction cycle
    breq     D_1mS_E    ;If zero            ;2 instruction cycles for branch, 1 for not branch
    dec    count_H        ; Count_L is R19    ;1 instruction cycle
    rjmp D_1mS_Loop2                    ;2 instruction cycles
D_1mS_E:
    ret
;                               -------------End of subroutines --------------
Les.
