Increase ir led range
swapnil_revankar2004
Joined Feb 16, 2013
5
Hi . i am working on laser tag gun project . i wanna increase my ir led range .i am currently getting a range of around 100 feet approximately but i wanna increase the range to about 500 feet or more. I am using a normal remote ir led and magnifying lens which helped me to achieve a 100 feet range . The ir led is provided with a 5 volts power through arduino . Plz help ...Thanks
tubeguy
Joined Nov 3, 2012
1,157
What is the current supplied to the IR LED?
What are the specs for the LED?
tubeguy
Joined Nov 3, 2012
1,157
The current supplied is 5 volts it is supplied through arduino . and the specs is double convex lens 40mm diameter and the focal length is 115 mm .
Voltage and current are 2 different things:
This might help:
http://www.allaboutcircuits.com/vol_1/chpt_2/1.html
If you are driving the LED from 5 volts you will need to limit the current through the LED (if you are not already doing that.)
Can you please post your circuit?
And the specifications for the LED -
I'm not an optics guy, maybe someone can shed some light on the lens ;)
Joined Feb 16, 2013
5
Hi
I did limit the current earlier with a 100 ohms resistor but then my range was about 50 feet.i did read in one forum that if we increase the power to led the range increases ,so i did that and was able to achieve a range of about a 100 feet.The ir led that i am using is 940nm led .
bertus
Joined Apr 5, 2008
23,005
You still have not provided the specs of the IR led.
A data sheet would be helpfull.
Also a drawing of the optical setup would be helpfull.
Joined Feb 16, 2013
5
Hi
Thnks for the post .After reading it what i understand is, i have to place the led at a point where the image gets blurred .Thats not what i have done now ,i have placed the led at point where the image is clear .so will try that ..Thank u ..
