Thank you! I will try it out todayhi,
I have used the HX711 many times.
This is a simple example of an Arduino Sketch.
E
C-like:#include "HX711.h" HX711 scale; void setup() { Serial.begin(38400); Serial.println("HX711 Demo"); Serial.println("Initializing the scale"); // parameter "gain" is ommited; the default value 128 is used by the library // HX711.DOUT - pin #A1 // HX711.PD_SCK - pin #A0 scale.begin(A1, A0); Serial.println("Before setting up the scale:"); Serial.print("read: \t\t"); Serial.println(scale.read()); // print a raw reading from the ADC Serial.print("read average: \t\t"); Serial.println(scale.read_average(20)); // print the average of 20 readings from the ADC Serial.print("get value: \t\t"); Serial.println(scale.get_value(5)); // print the average of 5 readings from the ADC minus the tare weight (not set yet) Serial.print("get units: \t\t"); Serial.println(scale.get_units(5), 1); // print the average of 5 readings from the ADC minus tare weight (not set) divided // by the SCALE parameter (not set yet) scale.set_scale(2280.f); // this value is obtained by calibrating the scale with known weights; see the README for details scale.tare(); // reset the scale to 0 Serial.println("After setting up the scale:"); Serial.print("read: \t\t"); Serial.println(scale.read()); // print a raw reading from the ADC Serial.print("read average: \t\t"); Serial.println(scale.read_average(20)); // print the average of 20 readings from the ADC Serial.print("get value: \t\t"); Serial.println(scale.get_value(5)); // print the average of 5 readings from the ADC minus the tare weight, set with tare() Serial.print("get units: \t\t"); Serial.println(scale.get_units(5), 1); // print the average of 5 readings from the ADC minus tare weight, divided // by the SCALE parameter set with set_scale Serial.println("Readings:"); } void loop() { Serial.print("A= "); Serial.print(scale.get_units(), 1); Serial.print(" Avg= "); Serial.println(scale.get_units(10), 1); // scale.power_down(); // put the ADC in sleep mode delay(1000); // scale.power_up(); }
