Nobody said it could. Read Wayne's post above.Your idea has a big problem, that is if the Power is +24V and the load is 24V and then the X circuit will be V_Xcircuit = 24V-24V = 0V, so how come a 0V can be supply the X circuit?
Yes, I read it before, and the TS didn't shows the whole picture including proximity detector and timer, maybe have some other else, he also didn't mention that why he want to in series the X circuit and load.Nobody said it could. Read Wayne's post above.
No, but he is obviously going to end up with a circuit like an illuminated doorbell as Wayne mentioned or he will run into all the problems you mentioned (unless you have an alternative solution to the problems that you identified).Yes, I read it before, and the TS didn't shows the whole picture including proximity detector and timer, maybe have some other else, he also didn't mention that why he want to in series the X circuit and load.
When I tried to designed a circuit for this thread, but I met the problem as I described, and many posters whatever in this forum or Taiwan, sometimes they just describe a prat of whole device and they thought that was enough, but in many situations their thinking have some blind point, so they will leading helpers to a unknown situations as going to the jungle and lost direction over there.No, but he is obviously going to end up with a circuit like an illuminated doorbell as Wayne mentioned or he will run into all the problems you mentioned (unless you have an alternative solution to the problems that you identified).
Why does he have to tell us the reason for his constraints? If he didn't have this constraint (series connection), the solution would no require him to post here - learn to trust people sometimes.
swap the "decorative light" for a lava lamp and you'll have a whole new groovy experience that the gym will never match.I had to wire an outlet to be on the same switch, and then I plugged a decorative bulb into that outlet. Then I joined a nice gym with a great spa and never use the one at home.
I want to made a sensor circuit with the output is in series with its self. See my attachment file for illustration.
Many device configured like my illustration i.e proximity detector and timer.
I just need the example design a blinking lamp.
| Thread starter | Similar threads | Forum | Replies | Date |
1 Series Oscilloscope | Test & Measurement | 2 | |
| M | Fluke 73 series 1 Multimeter repair | Technical Repair | 10 | |
| 7 | 7400 series's | Digital Design | 18 | |
Looking for help with wiring PJ Bass (Series/Parallel blend bypass) | General Electronics Chat | 1 | |
series resistors Vs. lowering the voltage | General Electronics Chat | 9 |
