Importing a manufacturer spice model to LTspice
Xavier Pacheco Paulino
Joined Oct 21, 2015
728
I have attached the folder of a PTC model I downloaded from the manufacturer page. The folder has many files, but I believe they are mostly simulation examples. This is I what I did to import the model, correct if I'm wrong:
1. Copy the .lib file to LTspice sub folder
2. Copy all of the .asy files into a single folder inside the LTspice sym folder
Does this assure the model and the symbol are going to be combined?
Joined Oct 21, 2015
728
hi XPP,
What I do first time around is to load all the files/models into the same folder, then check out the models by using test asc files in the same folder.
All your asc files run OK, except the TEST PTCvi, which does not converge.
E
Thank you. Yes, the tests files run OK. But what I want to do is to use this device in another circuit. Should I copy the whole folder to LTspice directory or copy individual files according to the extension as I did in post #1?
ericgibbs
Joined Jan 29, 2010
21,622
hi,
At the C:\Program Files\LTC level.
I have placed the Lib file in the LTS Lib folder and Sub folder
In the Sym folder I have added a folder named PTC and placed the asy files in that folder.
Also in the Sub folder I have placed the Txt files.
After running LTSpice the files in the Documentation folder are updated to match these additions.
The Program is now finding the models.
I sure there must be an easier way to do this operation, I was used to XP Pro with LTS XVI
E
Alec_t
Joined Sep 17, 2013
15,160
I usually just dump the new files directly in the appropriate sub or sym folder in the LTS section on the Documents path.
