Importance of a Resistance in this connection
Kadav
Joined May 11, 2018
158
Hello i am building this connection and i want to know what is the R3 in this set up
I would Imagine it's a pull down resistor , but in simulation ,when its not there it works also , so what it is it's importance..
Thanks .....
Irving
Joined Jan 30, 2016
5,109
Discharges the gate capacitance which your simulation may not model or visualise fully (depending on timing) and ensures a cleaner switch-off.
Also, that's a really bad MOSFET to use, what is your load?
jpanhalt
Joined Jan 18, 2008
11,087
R3 is a "turn off" resistor. Its purpose is to ensure the gate is discharged to be sure the mosfet is turned off. Often 1K or larger.
ericgibbs
Joined Jan 29, 2010
21,439
hi K,
A MOSFET has Gate capacitance, when the opto is switched On this Cap charges and the MOS is turned On.
In order to turn Off, the Gate capacitance requires a discharge path.
E
AlbertHall
Joined Jun 4, 2014
12,625
It's more than just the capacitance in this circuit.
The MOSFET gate is very high resistance and even when U1 is off there will still be some leakage current and therefore there will still be voltage on the MOSFET gate.
Kadav
Joined May 11, 2018
158
I have 3 questions regarding this
1) How do you know the MOSFET has a capacitor
2) why do we need to put the capacitor there( at the gate )
3) why do we need to discharge the capacitor
Delta Prime
Joined Nov 15, 2019
1,311
Hello there. :)for kicks and giggles why is the mosfet there?
Optocoupler output stages are not designed for high load currents. Maximum current levels for Darlington outputs are around 150 mA, and 300 mA is typical for SCR and TRIAC outputs. When high load currents are to be switched, the optocoupler output stage is used as a trigger circuit for a high power device.
R3 is there for voltage to develop across the resistor .
38,502
The voltage is there whether there is a resistor or not.
All MOSFET gates look like a capacitor.
We don't put it there, it's intrinsic to the MOSFET gate.
You must do that to change the gate voltage and turn the MOSFET off and on.
You can't change the voltage on a capacitor without charging or discharging it.
Kadav
Joined May 11, 2018
158
@crutschow Makes sens thanks
Kadav
Joined May 11, 2018
158
@Delta prime i would think that the opto coupler acts like a trigger for the MOSFET , but high currents don't actually pass through them, is n't it the case with my diagram ?
Audioguru again
Joined Oct 21, 2019
6,826
A power Mosfet has a high gate to source capacitance because it is made with thousands of tiny Mosfets in parallel and each tiny Mosfet has some capacitance that is multiplied by the thousands of them. Many tiny Mosfets are used so that their parallel on-resistance is very low.
Kadav
Joined May 11, 2018
158
How about if i remove the R2 what happens ? in my experience the motor runs faster because there is no resistance at the collector of the optocoupler , which in turn increases voltage at the gate of the MOSFET .
Irving
Joined Jan 30, 2016
5,109
That's true, because you're only putting about 8v on the gate with the 220ohm there, but the full 12v without it.
But it also shows you are not turning the MOSFET on hard enough AND its a rubbish MOSFET. That device has an ON-resistance of 4 - 5 ohms... not milliohms, OHMS!
A good MOSFET, say an IRLZ44, will have an ON-resistance of 25milliohms
The difference is you are probably losing 1 - 2 volts across the MOSFET, depending on the size of your motor. And that MOSFET is going to get very hot if you ask your motor to do any serious work.
A very good MOSFET eg IPP048N04N will have an ON-resistance of ~4milliohms
Kadav
Joined May 11, 2018
158
@Irving
OK Thanks very much , by the way like the IRLZ44N ,can we find it on actual electronics board normal appliances ?
since it takes me days to order these small items..
Thanks for the info it's very clear
Kadav
Joined May 11, 2018
158
As @Delta prime asked me i know , have the simillar question because i have to plug in a 10V 2A and at the MOSFET , is it safe to use that opto-coupler ?
