Implement a serial transmission system
tan.n.n
Joined Dec 23, 2019
Hi all,
My teacher gave me a topic below :
Here is a circuit I have designed, but it don't work properly and I don't know why. How can I fix this ?
Thanks in advance.
LesJones
Joined Jan 8, 2017
4,544
You also need to make the diagram clearer. Is it module 1 or module 2 or is it both modules ? I suspect it is both modules but the vertical orange line is the only thing that shows the division between the modules. BUT if it is then there are 5 wires connecting the modules. The only place where there is single wire path is between U6 and U2. If you give a description of how you have designed it to work then you may understand why it does not work. Here is a question that may help you understand why it does not work. How are U6 and U2 synchronised ?
Les.
