impedance of capacitor in pulsating DC
neko
Joined Apr 4, 2007
I know capacitors only work as impedance in AC circuit with the formula Xc=1/wC and thus in DC capacitors are an open circuit once charged
But my question is about a capacitor in a pulsating DC circuit, it is not AC so you are not allowed to use the Xc formula but in a pulsating DC there's a frecuency so maybe you could use that formula or a similar one.
What I mean is to calculate Xc in this circuit you use the formula Xc=1/wC
but what formula you have to use to calculate Xc in this circuit (if you can talk about Xc in this case)?
38,804
You can't/don't use Xc since pulsating DC contains many Fourier frequencies.
You can use the charge movement through a capacitor due to the rate-of-change of the DC voltage and the capacitor size to determine the momentary current (example LTspice sim below):
Note that if there's a diode in series with the capacitor (as the second circuit seems to show) then it will charge up to a fixed voltage, since there is no path for it to discharge..
