Impedance measurement scheme
anushaas
Joined Jul 18, 2011
3
I need to measure impedance over a range of 1 Ohm to 3 MOhm. The impedance variation happens over a frequency range of 2 MHz to DC (ie. impedance is 3 MOhm at DC and 1 Ohm at 2 MHz). Can any one suggest a suitable measurement scheme for measurement?
I thought about a constant current excitation scheme(ie.maintaining a constant current flow through the impedance and measure the voltage across it.The impedance will be the ratio of voltage and current).But for my pplication the current cannot be less than some 75uA. This however, makes the voltage across 3MOhm equal to 225V which is too high.
The constant voltage excitation,similarly, might cause a very low or high current flow at the extremes.
Can some one help me with a possible scheme of measurement which can incorporate all the constraints?
alfacliff
Joined Dec 13, 2013
2,458
thats a low enough frequency that a whetstone bridge circuit should work without much problem. use a signal generator to feed the bridge, and a scope to indicate.
12,142
You need to explain your overall situation in much more detail. In particular, where does the 75 uA minimum current come from? As you noted, that implies a very high voltage source. Whether it is constant current or constant voltage doesn't matter.
