Impedance in transformers
Borne
Joined Jan 7, 2021
6
I'm struggling to find the answer to (When the impedance connected across the secondary winding of a transformer decreases what happens to the current)
Borne
Joined Jan 7, 2021
6
hi Clay,
As this is Homework, please post what you consider the answer is to the question, we can then help you.
E
My thought is that both the primary and secondary current will decrease given that what happens on one side of the transformer will happen on the other.
MrAl
Joined Jun 17, 2014
13,761
If you have a relatively constant voltage source connected to a resistor and you lower the value of the resistor, does the current through the resistor (and also the source) increase or decrease?
