i'm making the LED dice with schematic on internet but i don't know this
MrSalts
Joined Apr 2, 2020
2,767
R5, R6 & R7 should be 220 ohms.
and
R4 should be 330 ohms.
This will keep current to all LEDs at the same brightness and within current limits of typical 3mm or 5mm bullet shaped LEDs.
dl324
Joined Mar 30, 2015
18,490
on breadboard.
if capacitor didn't installed, cd4017 keeps working and light the led whether switch is on/off
The problem is that the buzzer is acting like an impedance connecting the timer output to the enable pin. Using a capacitor to add delay on the rising edge of the clock is a kludge. You should work out a more robust way to enable the buzzer+counter.
