Hi Tony, that part was not intended as a question as it is well understood what is happening between the magnet and copper tube. The part in question being the use of gravity as the motive force acting on the magnet to cause it to fall.You got it.
Why do you feel the need to hijack the thread and appoint yourself as the TS's spokesman?Have you guys ever even done the experiment (magnet in a copper pipe)? If you have, you'll realize how stupid the conversation about air resistance is. It takes about 5 to 10 seconds for a good magnet to fall through a 1-foot pipe.
Your concern and prolonged hijacking of the thread to discuss air resistance on the magnet's fall through the pipe is like discussing how insects hitting your windshield lower fuel economy. If you guys don't have anything to add for the OP, sit quietly instead of hijacking.
The "work" done by gravity in either case is identical. Work is a force acting through a distance. In either case, the force of gravity on the magnet is the same and the distance through which it fell is the same. The energy associated with that work has to appear in some other form. Previously it appeared not as "gravity", but as gravitational potential energy as a consequence of the magnet being at a certain location within a gravitational field. When it is at the lower level, it has less gravitational potential energy. That different MUST appear as some other form. It might appear as kinetic energy in the falling magnet, it might appear as electrical energy that gets stored in a battery or that gets converted to heat in a resistance, it might get converted to sound and heat when the magnet hits the floor, it might get converted to some combination of these. But the total energy associated with all of those other forms (almost certainly including some minor ones that got dismissed or overlooked completely) exactly adds up to the work done by gravity as the magnet fell through that same distance, with or without the metal tube.Just to be clear, and I appreciate all the comments, Let us for a moment consider this........ Lets do the experiment in a vacuum, or have good clearance between the magnet and tube walls so any air compressive effect can be disregarded. The only thing of consequence causing the motion of the magnet to travel through the tube being gravity.
So, if we reverse the experiment, and apply a force to move the magnet from the bottom of the tube through to the top at the same rate of acceleration that gravity would in the downward direction, (32 ft per sec per sec) the amount of "work" required is greater than if the tube were not there. This because of the braking effect caused by the magnetic interaction. That "work" has been provided buy imparting energy by some means to lift it. If for instance, it where lifted by a cable to a petrol powered winch, the the fuel used by the winch is consumed to provide the work.
This brings me back to the question posed by the young chap. Gravity has acted on the magnet causing it to fall, magnetic interaction has "opposed" the rate of acceleration and slowed the fall, so "gravity has done "work" is that work energy "consumed"?
That was the part that I could not answer![]()
You are not paying attention and you're back to square one.This brings me back to the question posed by the young chap. Gravity has acted on the magnet causing it to fall, magnetic interaction has "opposed" the rate of acceleration and slowed the fall, so "gravity has done "work" is that work energy "consumed"?
Work was done in both directions. Work was done AGAINST gravity as you moved the cannonball up the hill. Work was done BY gravity as the ball came rolling back down.You are not paying attention and you're back to square one.
Gravity does not do any work. You have done the work already.
If you push a cannon ball up a hill and allow it to roll down the hill, gravity is not doing the work.
The work was already done by pushing the ball up the hill against gravity.
Quite analogous, which emphasizes what I just said (and I'm glad you mentioned it because it might clear things up a bit). Consider the ball on a spring. You pull on the ball and it extends the spring. You did work on the ball and the ball did an exactly equal amount of work on the spring (again, assuming the ball starts and ends at rest). The BALL doesn't contain ANY additional energy since the net work done it is was zero. But YOU did work, so where did that energy end up? The energy is stored in the spring. When the ball is released, work is now done ON the ball BY the spring. The spring transfers energy that was stored in it to the ball.If we put two masses in space and pull them apart, isn't the gravitational energy thus created analogous to the energy created by the stretching of a tension spring?
Just asking.
Then why did you suggest that the gravitational field is unlike a compressed spring?Unlike a compressed spring that stores mechanical energy, the ball is not storing gravitational energy. It is not a property of state. The energy is stored in the gravitational field, just like the energy in a capacitor is stored in the electric field and the energy in an inductor is stored in the magnetic field.
Different situation. The post you are quoting here didn't have a ball -- it had just a spring (instead of a ball). The proper analogy needs both. We don't have JUST gravitational fields (in this context, since they need to interact with masses or other things). We have an object (the ball) interacting with a gravitational field (the spring).Then why did you suggest that the gravitational field is unlike a compressed spring?
Work done by what on what? Frictionless ramps? Are the masses at rest both before and after the experiment? If so, how are they brought to rest?Two 6 ft high ramps. One at 30 degrees, one at 15 degrees. Identical masses...or use the same mass.
What's the difference in work done?
I could forgive thus phrasing because the quote marks are implying something - not clear but I won't push it. But this next sentence is the dumbest thing I have ever heard... The capitalization takes away all question of an implied meaning of work origin - you flat-out claim that gravity does work!?!?The "work" done by gravity in either case is identical. Work is a force acting through a distance
The work is done by the potential energy which is stored in the magnet when you lift it up. Or in other words, the energy comes from your hand. And it has no relation with air resistance. Here is a good video which explains the effect at the end:
Perhaps you should consider taking a high school physics course (although this is usually covered in middle school, so perhaps you need to go back further).I could forgive thus phrasing because the quote marks are implying something - not clear but I won't push it. But this next sentence is the dumbest thing I have ever heard... The capitalization takes away all question of an implied meaning of work origin - you flat-out claim that gravity does work!?!?
Work = force x distance
Force = mass x acceleration
Therefore,
Work = mass x acceleration x distance.
Since gravity is an acceleration, claiming gravity is doing work ("work was done BY gravity") is comperavle to saying something like Distance is done BY Velocity. Ignorant.
While the energy comes from your hand, it is not stored in the magnet. It is stored in the gravitational field. Now, you might be asking how this is possible when the gravitational field is the same both before and after you lift the magnet up. The answer is that it ISN'T the same. The gravitational field is a function of ALL the mass in the universe and, in particular, its distribution relative to the point in question. Move any of it, and you change the gravitational field at all points. But moving objects within the field requires force and that force either does work ON the field, thus increasing the energy stored in it, or resists work done BY the field, thus extracting energy from it. We don't perceive a change in the gravitational field when we move the magnet only because the change is so small in comparison to the strength of the field.The work is done by the potential energy which is stored in the magnet when you lift it up. Or in other words, the energy comes from your hand. And it has no relation with air resistance. Here is a good video which explains the effect at the end:
Well, that is a more detailed description of what happens actually. But while describing simple phenomena with Newtonian physics that "storing of gravitational potential energy" is more commonly used. For example, we use Newtonian gravity instead of Einstein's curved space-time when we describe the dropping down of an apple, although curved space-time is more true and rightly explained.While the energy comes from your hand, it is not stored in the magnet. It is stored in the gravitational field. Now, you might be asking how this is possible when the gravitational field is the same both before and after you lift the magnet up. The answer is that it ISN'T the same. The gravitational field is a function of ALL the mass in the universe and, in particular, its distribution relative to the point in question. Move any of it, and you change the gravitational field at all points. But moving objects within the field requires force and that force either does work ON the field, thus increasing the energy stored in it, or resists work done BY the field, thus extracting energy from it. We don't perceive a change in the gravitational field when we move the magnet only because the change is so small in comparison to the strength of the field.
Thinking of the energy as being stored in the magnet is generally a useful view, but it isn't what is actually happening. It's merely a useful shortcut.
| Thread starter | Similar threads | Forum | Replies | Date |
Tachometer suddenly died, wondering if the chip is likely still operational. | Technical Repair | 143 | |
Confused over "board layer" and clearance holes. | PCB Layout , EDA & Simulations | 2 |
