Hello everyone , newbie to the forum , i was working on a ignition cut off circuit using a mosfet , arduino nano and a switch could anyone help me out with the schematic ?? it would be really helpful
Welcome to AAC!
Why not use just the switch?[/QUOTE
With only a switch how can i give a 5v input to the mosfet , i am not sure about it , if you have a schematic for it it would be really helpful sir
How do you expect it to work? Your request is odd. The Arduino and MOSFET seem redundant.And im still working on the schematic to cut off ignition with a mosfet so it would be helpful if the schematic is shared
I have a push button switch through which im trying to cut off the ignition through a mosfetHow do you expect it to work? Your request is odd. The Arduino and MOSFET seem redundant.
Could you explain what you are tying to do?
But why are you using the MOSFET, and why is there an MCU involved?I have a push button switch through which im trying to cut off the ignition through a mosfet
I was working on a motorcycle quickshifter , i have to cut off the pulses or power supply going to the ht coil / ignition in the motorcycle while shifting the gear momentarily using a switch . Im using a mosfet instead of relay because of the switching timeBut why are you using the MOSFET, and why is there an MCU involved?
The reason for the questions is that just a switch is enough, and if you wanted a momentary switch to act as on/off, the Arduino is far more than is required. Is there something else going on that requires it?
OK, do you have a schematic or diagram showing what you are doing so far, and how you would expect this to work?I was working on a motorcycle quickshifter , i have to cut off the pulses or power supply going to the ht coil / ignition in the motorcycle while shifting the gear momentarily using a switch . Im using a mosfet instead of relay because of the switching time
