IGBT's and Short Circuits?
Sjöholm
Joined Jun 13, 2018
35
Dear All,
In several Infenion IGBT datasheets e.g. IKW50N60T I have found this text:
"Allowed number of short circuits: <1000; time between short circuits: >1s."
What constitutes a "short circuit" in this context? I have absolutely no clue, maybe someone could come up with a qualified answer?
Thank you.
Ejnar
DickCappels
Joined Aug 21, 2008
10,662
This is probably the number of times you can short circuit the load from 5 uS with Vcc < 400V, VGE of 15 volts (pr presumably less) when the junction temperature is less than or equal to 150°C.
DickCappels
Joined Aug 21, 2008
10,662
The specification applies to a shorted load, in other words, the collector connected directly to 400V and the emitter grounded. In most real circuits there is a load somewhere in that path which will limit the current.
Sjöholm
Joined Jun 13, 2018
35
OK, then this must be the short circuit condition:
So if I keep below the maximum rating I can disregard the ominous short circuit warning i.e.
