IGBT Inductive Switching Load
38,879
Not sure where that current spike is coming from. :confused:
It looks like you have a lot of capacitance at the IGBT's collector.
Measure and plot the current through D1 and L1 to see what those look like.
The diode should be rated for the supply voltage and the maximum inductor current.
CtyNatty
Joined Sep 10, 2017
12
Here is the waveform.
So the average forward current (IF) and breakdown voltage for diode should follow the maximum current through the inductor and supply voltage ?
38,879
Worst-case, yes.
For low duty-cycles you could get by with a smaller diode, if the diode peak current rating is more than the peak inductor current.
