IEC standards for electrical connector
Fanfire174
Joined Mar 13, 2018
240
Hello
I'm looking help to understand the information given in this link https://webstore.iec.ch/publication/29013 I don't understand what the information given in this page. I'm guessing IEC has some standards for electrical connectors. Specification of the manufacturing connector in a factory should be meet with IEC standards.
I don't know what are the test method and requirement. Can somebody help me to understand what is the information in the given link?
Thank you
MaxHeadRoom
Joined Jul 18, 2013
30,593
This page offers the ability to purchase and download the relevant IEC bulletin related to the standard you are interested in.
Max.
Fanfire174
Joined Mar 13, 2018
240
Max.
What's the meaning of this paragraph
Compression and mechanical connectors for power cables -
Part 1-3: Test methods and requirements for compression and mechanical connectors for power cables for rated voltages above 1 kV (Um = 1,2 kV) up to 30 kV (Um = 36 kV) tested on non-insulated conductors
MaxHeadRoom
Joined Jul 18, 2013
30,593
The bulletin states the standards required for means of compression for the mechanical connectors, (Lugs etc), I assume it indicates the required force exerted by the particular tooling involved in the process.
Max.
Fanfire174
Joined Mar 13, 2018
240
Max.
If I'm not wrong, I think below image shows the example of power cable and mechanical connectors.
How the power cable and mechanical connectors relate to IEC standards ?
MaxHeadRoom
Joined Jul 18, 2013
30,593
Correct, one type.
At one time many jurisdictions allowed the sweating (solder) on of lugs such as those, now most only allow compression.
Max.
