IEC 60364-5-52: Correction Factor for Two Multi-Core Cables in a Conduit – Need Help
Khangl2001
Joined Mar 21, 2025
Hi everyone,
I’m working on designing a low-voltage electrical installation using the IEC 60364-5-52 standard, and I have some questions about the correction factors for current-carrying capacity when installing cables.
Case 1: I have two multi-core cables (each with more than one core) placed in a single conduit. This conduit is installed alone, with no other conduits nearby or touching it. According to the IEC 60364-5-52 standard, what is the correction factor for the current-carrying capacity in this case? I found a factor of 0.85 in a table, but I’m not sure if it’s correct.
Case 2: In another scenario, I have one multi-core cable in a single conduit, and this conduit is touching another conduit (the distance between the two conduits is 0). What is the correction factor for this setup?
I have 12 single-core cables forming 4 three-phase circuits (each circuit consists of 3 single-core cables for L1, L2, and L3). The cables are arranged in 4 triangular groups, where each triangle contains 3 single-core cables (one three-phase circuit). These 4 triangular groups are placed side by side, touching each other, and the cables are installed on a perforated cable tray.
My questions are: What is the correction factor for the current-carrying capacity in this setup according to IEC 60364-5-52? and Can someone explain the reasoning behind choosing this correction factor?
I’ve attached a data table that I’m referring to for more context. This table lists the correction factors for cables laid in ducts in the ground. I need help confirming if I’m applying the correct factor, or if there’s another table in IEC 60364-5-52 that I should refer to instead.
I’m new to this standard, so any guidance on how to apply these correction factors correctly would be greatly appreciated. Has anyone worked with IEC 60364-5-52 and can share their experience?
Thanks in advance for your help!
28,600
The good news is that if you are following good practices the safety ground (green wire) conductors are not carrying current and thus not contributing to any temperature rise.
