Identifying transistor whether genuine or fake
dl324
Joined Mar 30, 2015
18,476
Here's a picture of a TO-3 I took apart when I was an R&D tech and was curious about what things look like when I was learning CAD:
Teardowns I've seen for newer devices all used bond wires to connect to the die. This device was from the 1970's.
The solder blob on the upper connection was a misguided attempt by me to reattach the lead that came loose.
Thurgajohn
Joined Mar 12, 2019
16
Thank you guys for the replies and sorry for late respond . I had an original mj15024 trans
taken from an old amplier but it spoiled. So i used this for comparison. So opened both mj15024
and 2sc1619 to compare the inside construction . What I found is the MJ trans has a big blue isulator at pins while the 2sc trans smaller insulator. The MJ has another thick layer of heatsink and 2sc just has small circle bump up as heatsink . MJ trans has big rengtular chip but 2sc has smaller rectungar chip . But then again the
MJ trans has high power, higher voltage and higher current rting, so maybe ... Then I got an idea to test , but I really dont know whether this is correct way to test. I use the 2sc trans to bypass a 12 v regulaor to power up osram bulp (12v /20w). I dont know how describe it but
If yiu look at the circuit diagram attached, you will undrstnd the exprmnt.
Thurgajohn
Joined Mar 12, 2019
16
I dont know why but half of what I had written above post is missing , so i write again. This is contunuition of above post. I use 2sc1619 to bypass the regulator. At certan point , say at 100ma the 2sc trans will stert conduct . Higher current will passthrough 2sc ,it ll measured by ammeter #1. When i test with one bulp it show 1.4A , after add one more bulp in shows 3.2A.
The voltmeter 1 show 30mv. The output voltage remai 12v. The 2sc1619 is 50watt it handle 40w load , so can it be an original? Should I measure the Vce and multipy it wuth Ic to calculate power handling of the trans? Is it rightway tto test a transistor? I highly appreacite your replies.
Thank you.
dl324
Joined Mar 30, 2015
18,476
You were already given a couple of tests. See if it will conduct the maximum continuous current specified in the datasheet (not mentioned earlier - also measure the saturation voltage). Operate the transistor in active mode and see if beta is in the specified range.
Be sure to provide adequate heat sinking.
I couldn't see much from the 2SC pictures - too blurry. Were all of the pictures with the white spot a covering on the suspected fake?
Thurgajohn
Joined Mar 12, 2019
16
Yes, the blue insulator one is MJ15024 (the first pic) , others are 2sc . When I opened the
2sc there was a dustlike substance on the top of the chip(2nd pic). I cleaned the grey dustlike
substance then therewas a white colour glue covered the chip( 4rth . pic). The 5th and 6th pic are after the white glue removed. The MJ tans doesnt have any glue on its chip.
atferrari
Joined Jan 6, 2004
5,029
Pictures in daylight are the best. Experiment a little to get reasonable settings. Avoid sun shining directly on them.
That white glue could be something similar to the grease coming inside the mechanical mouse to lubricate the wheel.
I found same inside of a 2N3055 (and others) I opened by carefuly filing the top cover.
Are you sure that the "dust" is not the result of sawing the cover?
