Identifying SMD part
Blue_Electronx
Joined Jun 10, 2019
112
I can't find anything related to this part. The SMD marking is D8H9A and the package is SOT23. It looks like a MOSFET to me, but not 100% sure without the datasheet. It's shorted and I have other boards with the same part burned.
dl324
Joined Mar 30, 2015
18,453
Many components come in SOT23. MOSFETs, BJTs, single diode, dual diode, zener, to name a few.
There are lists of SMD marking codes on the internet. See if you can find one.
Another option is to trace enough connectivity around the device in question to make educated guesses possible.
SamR
Joined Mar 19, 2019
5,533
jpanhalt came up with a MOSFET and my sites suggest a Voltage Regulator for D8... Both in the same typical SOT-23 case. H9A is also a V Reg. in SOT-23 so maybe dual marked???
