I have an ultrasonic transducer driver I am working on reverse engineering for when I inevitably blow it up, but all of the IC's have their markings scraped off.I figured out 99% of the IC's on the board, but this last one has me stumped.
It is an SOIC8, only pins 2,4,5,6, and 8 are connected to any traces. Pin 2 is 5v in from the Vref pin on a SG3525. Pin 4 is Gnd. Pin 5 &6 go to each side of an unpopulated 2 pin jumper.
Pin 8 is a 5v pk-pk square wave output at 60Hz.
Pin 8 goes to the RT pin on the SG3525 after passing through a 10k resistor, pass the cathode of an electrolytic cap (anode connected to 5v Vref), and then through a 150k resistor where it joins the pots used for frequency control.
In my experience, I have not ran across an IC with this behaviour and pinout.
I will post my schematic later if I am allowed.
