Identify component on circuit board.
MountainGuy
Joined Jan 15, 2017
36
Can anyone give me a guess as to what this component is ? It doesn't have any markings on it. Any way to determine the values if it's a capacitor or resistor ? Thanks.
Kjeldgaard
Joined Apr 7, 2016
476
Some optocouplers are in white enclosure.
But to get further, we need to see pictures both directly from above and from the solder side.
MaxHeadRoom
Joined Jul 18, 2013
30,658
Generally in these circumstances it is very difficult without doing a little reverse-engineering on the relation with other components and parts of the circuit to get a feel for what the component actually is.
I concur that many 6 pin IC's in white are opto couplers as in Fairchild examples.
Max.
MountainGuy
Joined Jan 15, 2017
36
I was just trying to get an idea of what type of component it was so I could evaluate it in context of the circuit. two of the legs are not connected and two are tied to ground. One goes through a capacitor to pin 2 of a 555 timer. The other goes through a resistor to a wire. I know this probably doesn't help much, but looking at whatever was suggested will help me. I was thinking it might be a opto.
DickCappels
Joined Aug 21, 2008
10,661
If it is in the power supply circuit (big capacitor(s), transformers/chokes, and rectifiers) there is a good chance it is an optical isolator. If it is, I am unimpressed with the creepage distance.
