I'm working on my personal PC Motherboard from a Dell Inspiron 15R-5521 Laptop (5YGGX, LA-910P, AA171). This came without a JTouch surface mounted connector that controls the touch screen on my laptop. I attached pictures here from a failed attempt to remove the connector from a scrap motherboard and the ribbon connector itself. Please help me ID the black female connector seen destroyed on the first two images (there's also the male cable connector and the actual area this will go on the motherboard labeled JTouch):
This is a 6-pin connector with rough dimensions off 9mm x 4mm, pitch is probably .8mm.
I know the pitch is not 1mm because I already purchased what I thought would be a good replacement only to find it was way too long and tall and the pitch was off: JST-SH with 1mm pitch, I learned about pitch on my quest for a replacement.
When I was poking around other junk motherboards, I found a camera PC Board that came off an Acer Aspire One. It has a similar connector style as the one I'm looking for, unfortunately, it was a 5-pin connector, not a six. The top of the black connector says "B" on one side and "JXT" on the other.
Thank you for viewing this request, I look forward to your responses.
