ICSP Confusion Pins With Different Names !
mixotrhica
Joined Aug 10, 2009
Hello everyone,
Wondering if someone can help me here.
I have a board that has a 6 pin ICSP dip plug on it. Board is a brick.
I need to see if I can wake the chip up. I have a Canakit R1301 pic programmer. It has a 6 pin SIP on it.
Like the pinouts here :
https://en.wikipedia.org/wiki/In-system_programming#/media/File:Icsp-pinouts.png
It is not clear to me if I can connect one to the other since they both list different pin names ?
Thanks !
AlbertHall
Joined Jun 4, 2014
12,652
What is the chip that is being programmed on the brick?
Connecting two incompatible ICSPs could cause damage - for instance Arduino ICSP uses only 5V signals whereas PIC ICSP uses 13V.
mixotrhica
Joined Aug 10, 2009
I have not connected them yet. Needed to make a cable. But I think you have given me my answer which is the two are not compatible? :)
mixotrhica
Joined Aug 10, 2009
The board I need to test has an ATMega2560. It has a 6 pin dip with ICSP on it. I can see the confusion now. The Pic programmer I have has the SIP 6 pin header coming out also marked ICSP but it makes sense that this is not compatible. I will go ahead and find the appropriate dongle / ICSP programming gadget to solve this problem.
Thanks for the help !
jpanhalt
Joined Jan 18, 2008
11,087
Welcome to AAC
We really need to know what chip you are trying to program.
The 6th pin cannot always be ignored:
Sorry, we cross posted.
