Icon MC2100LT-12 Treadmill Controller Not Powering Main Motor
Dapostrophus
Joined Nov 15, 2019
18
I dug out a microscope, and as far as I can tell, the microcontroller says: CY8C24423A
24PVX[black blob][unreadable lettering]
However, all the units I can find for sale that are model CY8C24423A-PVXI (and slight variations thereof) have 28 pins instead of the 20 on this chip. Am I reading it wrong? (It isn't clear at all, with some sort of gloss over top making it even harder to read.) Or is the obscured part something that will get me the 20-pin one I need?
Dapostrophus
Joined Nov 15, 2019
18
Hopefully this is what you were looking for, but if so, I think it does not bode well for the old PicMicro. You be the judge. Attaching a picture showing my test results for what I think you were asking for...
MaxHeadRoom
Joined Jul 18, 2013
30,808
Looks OK , 12v supply in and the regulated 5v out.
Normally after power up, there is a 3sec -,5 sec wait, and then red LED should light steady.
And flash when belt motor running.
Max.
Dapostrophus
Joined Nov 15, 2019
18
So would a lack of voltage being sent to the motor and the LED never lighting at all indicate a likely fried microcontroller chip? Or is there and other likely culprit or easy/straightforward way to test the chip?
Dapostrophus
Joined Nov 15, 2019
18
The solution is to replace the board. I have not been able to budget the money to get a replacement as of yet, unfortunately. They're like 100 bucks and up.
lambalain
Joined Dec 26, 2020
18
I know this is and old thread, but I have this same board MC2100LT-12. I have 2 fried resistor on it.
Would someone be able to read the color for me? These are R21 and R22 next to the rectifier.
Thanks a lot!
eyesee
Joined Oct 19, 2013
82
Just replacing the resistors may only temporarily solve the problem. You need to find out why they burnt out.
Can you post a photo of the board and components surrounding the burnt resistors.
lambalain
Joined Dec 26, 2020
18
I think the Q4 Mosfet is shorted, I soon as I ask for the belt to move I have full voltage on the output and the unit just goes in slow flashing mode (4 flash, pause, 4 flash,...) as it draws to much amps. If I put a lamp then the lamp goes to max intensity but the board continue to work.
Here are the R21 and R22 with my best guess temporary replacements.
