- Joined Jul 18, 2013
- 30,815
S4025 for the SCR.
Paste does NOT substitute for the thermal pad. !
If also CA What province are you in?MaxHR, I see how you spelled colour. Are you Canadian too?
Two-week update: the treadmill had several workouts (totalling about 15 hours and ~80km) and so far it is working fine!... Please update us in a few weeks or workouts if your treadmill continues to work properly. Thanks
I did the same thing on mine. In fact, I have two controllers and tested that MOSFET (Q5) and ended up replacing with an IRFP260M. Works great but ran for about 9 minutes of running and the controller electronics are still good but it threw a 20A breaker. I think it would have ran longer if I didn't run on it.Two-week update: the treadmill had several workouts (totalling about 15 hours and ~80km) and so far it is working fine!
Update: I lubricated my tread and in fact overlubricated with silicone spray so I ended up cleaning much of treadmill. Once I got it back together, it actually moved faster than it used to while I was running and I haven't had a problem yet since cleaning and lubricating the belt.I did the same thing on mine. In fact, I have two controllers and tested that MOSFET (Q5) and ended up replacing with an IRFP260M. Works great but ran for about 9 minutes of running and the controller electronics are still good but it threw a 20A breaker. I think it would have ran longer if I didn't run on it.
Do you think it is a matter of lubrication? The great thing is that the control electronics are still fine but the treadmill isn't useable if it pulls more than 20 amps.
Hola a todos, necesito ayuda adicional con esta placa. Aquí está el contexto. Cinta de correr Nordictrack 1750. La banda funcionaba durante una fracción de segundo y luego se detenía. El LED en la placa de control del motor parpadeaba 4 veces (controlador defectuoso) y otras veces 3 veces (consumo excesivo de corriente al motor). Pedí un nuevo reemplazo de placa de control del motor pn#MC1648DLS (que reemplaza al MC2100LTS-50 original) e instalé la placa. El motor funcionó durante unos 30 segundos y se detuvo. El mismo problema y el mismo parpadeo del LED. El motor se probó bien con una batería externa, pero lo reemplacé de todos modos porque era viejo. Instalé un nuevo motor y encontré los mismos problemas. Descubrí que la resistencia R36 cerca de la cuchilla de tierra se quemó en la nueva placa después del intento original de funcionamiento. Reemplacé la resistencia y todavía tengo el mismo problema. Acabo de tomar una medición de voltaje en los terminales A+ A- en la placa al seleccionar el inicio en la cinta de correr. El voltaje va directo a 166 VCC. Parece que la placa envía el voltaje máximo al motor inmediatamente, lo que provoca un consumo excesivo de amperaje y la placa se apaga y parpadean 3 LED. ¿Parece correcto? De ser así, ¿qué componente de la placa lo controla? ¿Hay otras cosas que probar? De ser así, ¿cuáles? Soy principiante en esto, pero no quiero que el problema se agrave. Agradecería cualquier ayuda. ¡Gracias!
[/CITA]
Saludos debes revisar el transistor de potencia de tu placa va a estar dañado el Culpable tu motor viejo lo quemó luego cambiaste motor nuevo pero no revisaste tu transistor antes de instalarlo y un motor en buen estado deberá estar en .22 mA de consumo pasando a .40 o .50 ya esta malo Saludos
