IC Selection
Shilpa777
Joined Apr 24, 2023
20
Is TC4SU69F Toshiba CMOS IC, a good choice for designing an oscillator circuit with 17kHzcrystal input? What are the factors to be considered for designing an oscillator circuit without getting cross talk and jitter noise?
Ian0
Joined Aug 7, 2020
13,131
No, because it has been discontinued.
Don‘t waste your effort designing in something you won’t be able to buy later.
I‘ve never seen a 17kHz crystal either.
Shilpa777
Joined Apr 24, 2023
20
Hey Thanks,
Where can I find the information regarding ICs discontinued and new models?
My application is unique with low frequency crystals...
ronsimpson
Joined Oct 7, 2019
4,691
Digikey has 25,000 parts. When I look up that party. If I try to find inventory another way I see only 3000. I am not certain.
Quest thinks there is a real of them. I have never worked with them.
Shilpa777
Joined Apr 24, 2023
20
Which is the best new CMOS inverter IC to design a crystal oscillator typically low frequency application?
Ian0
Joined Aug 7, 2020
13,131
74hcu04 seems to be popular With 32.768kHz crystals, but most applications have the oscillator built into another IC.
At that frequency you could probably use an op-amp.
Are you trying to produce a sinewave or a squarewave?
Shilpa777
Joined Apr 24, 2023
20
sinewave
