IC manufacturer, functionality and identification of components
Erik_K
Joined Aug 13, 2021
I am looking for the manufacturer, functionality and identification of components of the attached IC.
The marking on the partly damaged package reads (? = unreadable):
A ????
MQ946022
2005? (probably a D)
The marking on the IC reads:
AMC0
23C_10
Any information would be much appreciated.
35,307
Welcome to AAC!
It would help if you provided more information.
1) Is this a board or IC?
2) What kind of unit or device was this component located? What is the function of the unit?
3) Can you provide a wider view of the device or the PCB on which it was located? i.e. we need to see and understand the bigger picture.
Erik_K
Joined Aug 13, 2021
Welcome to AAC!
Thanks!
This is an IC.
Unit or device and function are unknown. The latter is what I am trying to find out.
Attached is the PCB with the location of the IC.
I hope this helps.
twohats
Joined Oct 28, 2015
621
Hi Eric,
Have you salvaged that object off the Titanic, did you notice the swimming pool was still full?
Can you tell us what the circuit belongs to?
Good luck..........
