IC Info?
moorejohn90
Joined Dec 9, 2011
57
Hi, Is there any book or online resource that give IC' number, specification and where to use it, how to use. I am new to electronic and I don't know much about IC.
Thanks;)
praondevou
Joined Jul 9, 2011
2,942
Thanks;)
There are probably hundreds of thousands different ICs available. I don't know of one site describing the functions of each and every IC.
You can have a look on digikey.com.
A better approach is to tell us about a specific project and we tell you what chip you may use.
Rbeckett
Joined Sep 3, 2010
208
John,
The parametric search function on Digikey is about as close as youre gonna come to a chip cheat sheet like you describe. There are a few manufacturer specific booklets tha do a fair job explaining what the CMOS 4000 series does and the 74XX series of ships too. With the ever increasing number of chips and the amount of integration they are getting all the time a book would be nearly impossible to keep current. If you have a project, speak up with what you want to do and someone will have a chip that they use for that application. Once you have a chip then you can look at possible substitutions and see if you have something that will work in your parts boxx already. Hope this helps.
Bob
JohnInTX
Joined Jun 26, 2012
4,787
.. is online here
Back in the day it was a set of thick volumes that you could get for free every year with a gazillion parts listed by function. Its advertiser supported but check it out. Once you have browsed and know the kind of IC you want, drill down w/parametric searches on various ones as suggested above.
bertus
Joined Apr 5, 2008
23,005
The EDUCYPEDIA has a lot of pages for data with links about a lot of subjects:
Audio data
AWG conversion
Barcode
Calculators
Capacitor codes
Constants and tables
Databank - tables
Datasheets
Formulas
Inductor codes
IP ratings
Keyboard codes
Resistor color code
RF data
Schematic symbols
Science symbols-codes
SMD codes
Transistor codes
Units & constants
As the internet is very volatile, some of the links may show dead.
Many of them can be viewed using the internet archive:
http://archive.org/web/web.php
38,784
I like using a resource like Digi-key since it lists only devices that are generally available and commonly used, and gives basic information on their use. Also you get a quick check of whether it's in your price range. A general search will likely give many devices that are old, obsolete, and likely unavailable.
