IC for video amplifier and filter
roboticvn
Joined Jul 9, 2014
47
I am making a transmit video signal circuit. I need an IC to amplify and filter the video signal. Can you show me ic how best to do this job. Thank you ^^
roboticvn
Joined Jul 9, 2014
47
What type of video signal and over what medium do you want to transfer it?
I want to transmit composite video signal (NTSC) which uses 3.58MHz sub-carrier frequency. The signal after amplification is taken into pulse width modulation. Can you tell me what the best IC for this work? Thank you^^
roboticvn
Joined Jul 9, 2014
47
DickCappels
Joined Aug 21, 2008
10,661
You can firs try this without the filter or the amplifier, and if you test with a test pattern that does not change with time, you can connect the video to a DC restore (AKA clamp) circuit to the comparator. You will need a pretty fast sawtooth; I suggest 4x subcarrier otherwise you will get terrible beats between the sampling sawtooth and the subcarrier. Use a fast comparitor like the LM710.
Later you can add a 4.5 MHz low-pass filter to the input.
The circuit below includes an clamp and an 3.5 x amplifier. Adjust R29 to change the gain.
Dodgydave
Joined Jun 22, 2012
11,395
It does mention some ics for video and audio, TVL3502 op amp, Si1563 mosfet, AK5386 ADC,
its using optical transmission of video and audio using a pwm carrier of 15Mhz at a distance of 50 to 100 cm.
roboticvn
Joined Jul 9, 2014
47
TVL3502 is used as a comparator. AK5386 is a ADC. I need a IC for amplifier and filter video signal. This isn't mentioned in journey.
