hI
I would like to ask if any ic family of digital gate can frive a led diode?
thank you
George
thank you
George
There are many kinds of logic.ic family of digital gate
The Texas Instruments datasheet I posted shows that with a 10V supply, the output current is typically 16mA into two 2V red LEDs in series without a current limiting resistor.My point was intended to be that the 4000 series of CMOS CAN drive an LED to a useful intensity.. I doubt that the current was even close to 20 mA, but because they were "high brightness" devices the light at 5mA was bright enough.
What you mean by LED behavior is dependent on logic family? An LED behaves the same regardless of the logic family you're using.thank you ! the behavor of led depedent from the logic familly
i think in 74LSxx maybe need a external supply volatage with a serie resistor to protect LED..
Different logic families are able to sink or source vastly different amounts of current and output different voltages. And an LED behaves differently depending on how much current is passing through it, and that current often depends on the voltage pushing it.What you mean by LED behavior is dependent on logic family? An LED behaves the same regardless of the logic family you're using.
Yes this i mean... if the the IC family sink a current of μΑ led cant open and in this case need an external dc voltageDifferent logic families are able to sink or source vastly different amounts of current and output different voltages. And an LED behaves differently depending on how much current is passing through it, and that current often depends on the voltage pushing it.
You will find many LED's today that work well with currents of 0.5 mA to 2 mA . Digikey shows 628 hits for that range and that number douobles if you increase the range to 5 mA.according TO FLOYD BOOK (digital fundanental)
Most LEDs require currents in the range of about 10 mA to 50 mA.
Certainly this is true. Quite a while back I was using the high brightness yellow LEDs driven by the CMOS low output one-shot gates and they were not loading the outputs very much at all. So some LEDs can work on a very low current. The light will not be as much as at the rated max current, but still, they are working.You will find many LED's today that work well with currents of 0.5 mA to 2 mA . Digikey shows 628 hits for that range and that number douobles if you increase the range to 5 mA.
Most LEDs don't require 10-50mA to emit light. When used as indicators, high brightness LEDs can sometimes be operated at 1mA or less; even standard LEDs will light with 1mA. They won't be very bright, but they will turn on.Most LEDs require currents in the range of about 10 mA to 50 mA.
M | Mixing Logic Families | Digital Design | 7 | |
M | Logic Families and Complementary Outputs | Digital Design | 15 | |
Why Do We Need a Matched Termination With High Speed Logic Families? | AAC Contributors Forum | 2 | ||
S | Logic families - 5426 v 54LS26 | Digital Design | 9 | |
I | Digital families and analgue devices | Homework Help | 4 |
