1. I need a I2C to RS485 converter. Preferred is hardware based solution so that no MCU programming is required & low power since system is battery powered.
2. I2c specs are attached to be matched. If 400khz is fast, then I can limit 100Khz.
3. I was loking for MAX1307 and SC16IS750IBS.
looks like they can fit the solution.
4. Any other suggestions or better solution? Provided low power & dont want to add code/MCU support in it, looking for hardware based solution.
5. Only single I2C device will be connected. No more than that. i2C pins are pulled by 10K to 3.3Vdc
