Not far, as they are both connected through a header pin connector. While testing with the dev. board I am using dupont wires, and I can see that the quality of the signal gets worse, but it is just for testing. The PCB length is about 250mm, so the I2C bus is "long"Do these signals go between two PCB's? How far physically are you sending this data?
