Hey guys, If im reading from a control chip (DS2482-800) using the I2C peripheral, is there a way i can get the IO port address that that chip read from? instead of getting SDA OR SCL addresses?
Correct me if I'm wrong, but I'm still not clear on which addresses were being referred to. BMorse is correct on the details of the 7 bit address used on the I2C bus, but there is also the 48 bit unique identifier used by the 1-wire device itself. Since there appears to be no mechanism for that quantity to be read by the DS2482-800 into some internal register so that it can be obtained over the I2C bus, I'm going to assume that the OP's question was answered.
Hey guys the UBW32 site is down for some reason i need to download the Firmware V.1.3 can anybody attach it so that i can save it here?
Thanks
by Robert Keim
