Well, I guess I probably shouldn‘t wait for an answer then!The TS was last seen in Aug 11.
Ron;For analog most ICs are designed by using building blocks that you do not get to make changes to. TI has a big list of analog blocks like a PGA103 amplifier building block. It just works and you wire it up in the compiler. Pin52 connects to the output.
The compilers I used does not care if you know what a transistor is or not.
Hi,If I want to design a chip myself, where to start with? I am a electrical engineer.
Out of interest, how did you calculate the change in reliability ?Whenever I have a requirement for some unusual IC function I first investigate the "Special Functions" listing from the major IC producers. That has always worked so far. And for one of our rather successful products, a student engineer hired by our management suggested combining several standard IC functions into one package to reduce the IC cost of the product. That would have both increased the cost and reduced the reliability provided by the system redundant arrangement.
In general, a first time "spin" of a device designed by a beginner is less likely to be reliable than devices produced over many generations by organizations that have a record of reliable products. In addition, I considered that particular individual's skill level. Which was "Fair."Out of interest, how did you calculate the change in reliability ?
Do subjective and experience are as good as most mathamatical methods .In general, a first time "spin" of a device designed by a beginner is less likely to be reliable than devices produced over many generations by organizations that have a record of reliable products. In addition, I considered that particular individual's skill level. Which was "Fair."
